An integro-differential operator approach to linear differential systems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Une approche par opérateurs intégro-diférentiels des systèmes différentiels linéaires
In this paper, we initiate a new algebraic analysis approach to linear differential systems based on rings of integro-differential operators. Within this algebraic analysis approach, we first interpret the method of variations of constants as an operator identity. Using this result, we show that the module associated with a state-space representation of a linear system is the same as the one associated with its standard convolution representation. This finitely presented module over the ring of integro-differential operators is proved to be stably free. Finally, we show how the reachability property can be expressed within this algebraic analysis approach.
MTNS_final.pdf (253.87 Ko) Télécharger le fichier
hal-03908541 , version 1 (20-12-2022)
Alban Quadrat. An integro-differential operator approach to linear differential systems. MTNS 2022 - 25th International Symposium on Mathematical Theory of Networks and Systems, Sep 2022, Bayreuth, Germany. ⟨10.1016/j.ifacol.2022.11.054⟩. ⟨hal-03908541⟩
38 Consultations
34 Téléchargements
