An Integro-differential Operator Approach to Linear State-space Systems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
In this paper, the algebraic analysis approach to linear state-space systems is further developed using rings of integro-differential operators. The module structure of linear state-space systems is investigated over these rings. The module associated with a linear state-space system is shown to be the direct sum of the stably free module defined by the linear system without inputs and the free module defined by the inputs of the system.
main_final.pdf (225.33 Ko) Télécharger le fichier
hal-03908550 , version 1 (20-12-2022)
Alban Quadrat. An Integro-differential Operator Approach to Linear State-space Systems. SSSC 2022 - 8th IFAC Symposium on System Structure and Control, Sep 2022, Montreal, Canada. ⟨10.1016/j.ifacol.2022.11.299⟩. ⟨hal-03908550⟩
23 Consultations
49 Téléchargements
