Coupling finite elements of class C1 on composite curved meshes for second order elliptic problems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue International Journal for Numerical Methods in Fluids Année : 2023
Finite elements of class C1 are suitable for the computation of magnetohydrodynamics instabilities in tokamak plasmas. In addition, isoparametric approximations allow for a precise alignment of the mesh with the magnetic field line. Mesh alignment is crucial to achieve axisymmetric equilibria accurately. It is also helpful to deal with the anisotropy nature of magnetized plasma flows. In this numerical framework, several practical simulations are now available. They help to understand better the operation of existing devices and predict the optimal strategies for using the international ITER tokamak under construction. However, a mesh-aligned isoparametric representation suffers from the presence of critical points of the magnetic field (magnetic axis, X-point). We here explore a strategy that combines aligned mesh out of the critical points with non-aligned unstructured mesh in a region containing these points. By this strategy, we can avoid highly stretched elements and the numerical difficulties that come with them. The mesh-aligned interpolation uses bi-cubic Hemite-Bezier polynomials on a structured mesh of curved quadrangular elements. On the other hand, we assume reduced cubic Hsieh-Clough-Tocher finite elements on an unstructured triangular mesh. Both meshes overlap, and the resulting formulation is a coupled discrete problem solved iteratively by a suitable one-level Schwarz algorithm. In this paper, we will focus on the Poisson problem on a two-dimensional bounded regular domain. This elliptic equation is a simplified version of the axisymmetric tokamak equilibrium one at the asymptotic limit of infinite major radius (large aspect ratio).
BGNRsubDec2022.pdf (761.92 Ko) Télécharger le fichier
hal-03913143 , version 1 (26-12-2022)
Ashish Bhole, Hervé Guillard, Boniface Nkonga, Francesca Rapetti. Coupling finite elements of class C1 on composite curved meshes for second order elliptic problems. International Journal for Numerical Methods in Fluids, 2023, ⟨10.1002/fld.5241⟩. ⟨hal-03913143⟩
98 Consultations
69 Téléchargements
