Feedback Classification and Optimal Control with Applications to the Controlled Lotka-Volterra Model - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2023
Let M be a σ-compact C^∞ manifold of dimension n ≥ 2 and consider a single-input control system: ẋ(t) = X (x(t)) + u(t) Y (x(t)), where X , Y are C^∞ vector fields on M. We prove that there exist an open set of pairs (X , Y ) for the C^∞ –Whitney topology such that they admit singular abnormal rays so that the spectrum of the projective singular Hamiltonian dynamics is feedback invariant. It is applied to controlled Lotka–Volterra dynamics where such rays are related to shifted equilibria of the free dynamics.
feedback_equi_generecity.pdf (368.58 Ko) Télécharger le fichier
hal-03917363 , version 1 (01-01-2023)
  • HAL Id : hal-03917363 , version 1
Bernard Bonnard, Jérémy Rouot. Feedback Classification and Optimal Control with Applications to the Controlled Lotka-Volterra Model. 2023. ⟨hal-03917363⟩
163 Consultations
107 Téléchargements
