High order numerical methods for Vlasov-Poisson models of plasma sheaths - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2023
This article is a report of the CEMRACS 2022 project, called HIVLASHEA, standing for "High order methods for Vlasov-Poisson models for sheaths". A two-species Vlasov-Poisson model is described together with some numerical simulations, permitting to exhibit the formation of a plasma sheath. The numerical simulations are performed with two different methods: a first order classical finite difference (FD) scheme and a high order semi-Lagrangian (SL) scheme with Strang splitting; for the latter one, the implementation of (non-periodic) boundary conditions is discussed. The codes are first evaluated on a one-species case, where an analytical solution is known. For the two-species case, cross comparisons and the influence of the numerical parameters for the SL method are performed in order to have an idea of a reference numerical simulation. Aknowledgements Centre de Calcul Intensif d'Aix-Marseille is acknowledged for granting access to its high performance computing resources.
cemracs_hivalshea.pdf (6.11 Mo) Télécharger le fichier
hal-03926305 , version 1 (06-01-2023)
  • HAL Id : hal-03926305 , version 1
Valentin Ayot, Mehdi Badsi, Yann Barsamian, Anaïs Crestetto, Nicolas Crouseilles, et al.. High order numerical methods for Vlasov-Poisson models of plasma sheaths. 2023. ⟨hal-03926305⟩
212 Consultations
109 Téléchargements
