Mapping the Energy Landscape from a Nanocrystal-Based Field Effect Transistor under Operation using Nanobeam Photoemission Spectroscopy - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Nano Letters Année : 2023
Huichen Zhang
Adrien Khalili
Claire Abadie
Dario Mastrippolito
Yoann Prado
Mathieu Silly
  • Fonction : Auteur
José Avila
  • Fonction : Auteur
As the field of nanocrystal-based optoelectronics matures, more advanced techniques must be developed in order to reveal the electronic structure of nanocrystals, particularly with devicerelevant conditions. So far, most of the efforts have been focused on optical spectroscopy, and electrochemistry where an absolute energy reference is required. Device optimization requires probing not only the pristine material but also the material in its actual environment (i.e., surrounded by a transport layer and an electrode, in the presence of an applied electric field). Here, we explored the use of photoemission microscopy as a strategy for operando investigation of NC-based devices. We demonstrate that the method can be applied to a variety of materials and device geometries. Finally, we show that it provides a direct access to the metal-semiconductor interface band bending as well as the distance over which the gate effect propagates in field-effect transistors.
antaresmappingE_v28.pdf (919.01 Ko) Télécharger le fichier
hal-03954965 , version 1 (24-01-2023)
Mariarosa Cavallo, Erwan Bossavit, Huichen Zhang, Corentin Dabard, Tung Huu Dang, et al.. Mapping the Energy Landscape from a Nanocrystal-Based Field Effect Transistor under Operation using Nanobeam Photoemission Spectroscopy. Nano Letters, 2023, 23 (4), pp.1363-1370. ⟨10.1021/acs.nanolett.2c04637⟩. ⟨hal-03954965⟩
117 Consultations
65 Téléchargements
