Beating binary powering for polynomial matrices - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2023
The $N$th power of a polynomial matrix of fixed size and degree can be computed by binary powering as fast as multiplying two polynomials of linear degree in $N$. When Fast Fourier Transform (FFT) is available, the resulting arithmetic complexity is \emph{softly linear} in $N$, i.e. linear in $N$ with extra logarithmic factors. We show that it is possible to beat binary powering, by an algorithm whose complexity is \emph{purely linear} in $N$, even in absence of FFT. The key result making this improvement possible is that the entries of the $N$th power of a polynomial matrix satisfy linear differential equations with polynomial coefficients whose orders and degrees are independent of $N$. Similar algorithms are proposed for two related problems: computing the $N$th term of a C-recursive sequence of polynomials, and modular exponentiation to the power $N$ for bivariate polynomials.
BoNeYu23.pdf (598.97 Ko) Télécharger le fichier
ratio_urit_vs_bp_N22.pdf (8.82 Ko) Télécharger le fichier
ratio_urit_vs_bp_deg2.pdf (9.39 Ko) Télécharger le fichier
ratio_urit_vs_bp_ord4.pdf (9.4 Ko) Télécharger le fichier
BoNeYu23.tex (88.72 Ko) Télécharger le fichier
acmart.cls (114.34 Ko) Télécharger le fichier
Format : Figure, Image
hal-03979664 , version 1 (08-02-2023)
hal-03979664 , version 2 (26-05-2023)
Paternité
  • HAL Id : hal-03979664 , version 1
Alin Bostan, Vincent Neiger, Sergey Yurkevich. Beating binary powering for polynomial matrices. 2023. ⟨hal-03979664v1⟩
103 Consultations
118 Téléchargements
