Beating binary powering for polynomial matrices
The $N$th power of a polynomial matrix of fixed size and degree can be computed by binary powering as fast as multiplying two polynomials of linear degree in $N$. When Fast Fourier Transform (FFT) is available, the resulting arithmetic complexity is \emph{softly linear} in $N$, i.e. linear in $N$ with extra logarithmic factors. We show that it is possible to beat binary powering, by an algorithm whose complexity is \emph{purely linear} in $N$, even in absence of FFT. The key result making this improvement possible is that the entries of the $N$th power of a polynomial matrix satisfy linear differential equations with polynomial coefficients whose orders and degrees are independent of $N$. Similar algorithms are proposed for two related problems: computing the $N$th term of a C-recursive sequence of polynomials, and modular exponentiation to the power $N$ for bivariate polynomials.
