Explicit bounds for the high-frequency time-harmonic Maxwell equations in heterogeneous media - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2023
We consider the time-harmonic Maxwell equations posed in $\mathbb{R}^3$. We prove a priori bounds on the solution for $L^\infty$ coefficients $\epsilon$ and $\mu$ satisfying certain monotonicity properties, with these bounds valid for arbitrarily-large frequency, and explicit in the frequency and properties of $\epsilon$ and $\mu$. The class of coefficients covered includes (i) certain $\epsilon$ and $\mu$ for which well-posedness of the time-harmonic Maxwell equations had not previously been proved, and (ii) scattering by a penetrable $C^0$ star-shaped obstacle where $\epsilon$ and $\mu$ are smaller inside the obstacle than outside. In this latter setting, the bounds are uniform across all such obstacles, and the first sharp frequency-explicit bounds for this problem at high-frequency.
chaumontfrelet_moiola_spence_2023a.pdf (666.73 Ko) Télécharger le fichier
hal-04001866 , version 1 (23-02-2023)
Théophile Chaumont-Frelet, Andrea Moiola, Euan A. Spence. Explicit bounds for the high-frequency time-harmonic Maxwell equations in heterogeneous media. 2023. ⟨hal-04001866⟩
40 Consultations
26 Téléchargements
