On Quasipolynomials Real Roots Coexistence: Effect on Stability of Time-Delay Systems with Perspectives in Partial Pole Placement - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
In this work, which is a natural continuation of [1] and [2], we show, that the coexistence of the maximal number of real spectral values of generic single-delay retarded second-order differential equations guarantees the realness of the rightmost spectral value. This is interpreted from a control theory point of view as, using a delayed PD controller, one can stabilize a second-order delay differential equation by assigning the maximal number of negative roots of the corresponding characteristic function (which is a quasipolynomial). We give a necessary and sufficient condition for the rightmost root to be negative and thus guarantee the exponential decay rate of the system solutions. We illustrate the proposed design methodology in the delayed PD control of the harmonic oscillator.
crrid_tschmoderer_ecc23.pdf (225.86 Ko) Télécharger le fichier
Licence : CC BY NC SA - Paternité - Pas d'utilisation commerciale - Partage selon les Conditions Initiales
hal-04028886 , version 1 (14-03-2023)
  • HAL Id : hal-04028886 , version 1
Timothée Schmoderer, Islam Boussaada, Silviu-Iulian Niculescu, Fazia Bedouhene, Amira Remadna. On Quasipolynomials Real Roots Coexistence: Effect on Stability of Time-Delay Systems with Perspectives in Partial Pole Placement. 2023 European Control Conference (ECC 2023), Jun 2023, Bucharest, Romania. ⟨hal-04028886⟩
118 Consultations
48 Téléchargements
