A generic power wheelchair lumped model in the sagittal plane: towards realistic self-motion perception in a virtual reality simulator - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
This paper presents a generic power wheelchair dynamic model. As a first contribution, this paper proposes to use a generic model composed of a geometric model and a lumped model in order to be compliant with a wide range of existing commercially available wheelchairs. In this model, a set of essential parameters are enough to accurately replicate the dynamic behavior of a wheelchair. As a second contribution, this paper presents an identification method of a n-wheel type power wheelchair. The presented model is restricted to the sagittal plane only, which is sufficient to study the reliability of the identification and validation methods. Moreover, a Motion Cueing Algorithm based on the proposed model controls a simulator mechanical platform. The generic model has been then validated through a user study with 18 able-bodied participants evaluating the self-motion perception with our multisensory power wheelchair driving simulator. Results show that the simplified model is sufficient to provide accurate sensations to the user with respect to their experience while driving a power wheelchair.
2023_icra_Grzeskowiak.pdf (748.19 Ko) Télécharger le fichier
hal-04044201 , version 1 (24-03-2023)
Paternité
  • HAL Id : hal-04044201 , version 1
Fabien Grzeskowiak, Ronan Le Breton, Louise Devigne, François Pasteau, Marie Babel, et al.. A generic power wheelchair lumped model in the sagittal plane: towards realistic self-motion perception in a virtual reality simulator. ICRA 2023 - IEEE International Conference on Robotics and Automation, IEEE, May 2023, Londres, United Kingdom. pp.1-6. ⟨hal-04044201⟩
80 Consultations
89 Téléchargements
