Observability estimates for the Schrödinger equation in the plane with periodic bounded potentials from measurable sets - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2023
Kévin Le Balc’h
  • Fonction : Auteur
  • PersonId : 1076983
Jérémy Martin
  • Fonction : Auteur
  • PersonId : 1247585
The goal of this article is to obtain observability estimates for Schrödinger equations in the plane R 2. More precisely, considering a 2πZ 2-periodic potential V ∈ L ∞ (R 2), we prove that the evolution equation i∂tu = −∆u + V (x)u, is observable from any 2πZ 2-periodic measurable set, in any small time T > 0. We then extend Taüffer's recent result [Täu22] in the two-dimensional case to less regular observable sets and general bounded periodic potentials. The methodology of the proof is based on the use of the Floquet-Bloch transform, Strichartz estimates and semiclassical defect measures for the obtention of observability inequalities for a family of Schrödinger equations posed on the torus R 2 /2πZ 2 .
main_14Sept2023.pdf (550.06 Ko) Télécharger le fichier
hal-04069809 , version 1 (14-04-2023)
hal-04069809 , version 2 (14-09-2023)
Kévin Le Balc’h, Jérémy Martin. Observability estimates for the Schrödinger equation in the plane with periodic bounded potentials from measurable sets. 2023. ⟨hal-04069809v2⟩
41 Consultations
109 Téléchargements
