On DREM regularization and unexcited linear regression estimation - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
The problem of estimation of unknown constant parameters in the linear regression with measurement noise is considered. Analysing different levels of excitation of the regressor, two notions of partial and feeble excitation are introduced. The former implies the absence of the persistent or interval excitation, while the latter property says that the excitation is just insufficient for an efficient estimation in a noisy setting. The dynamic extension and mixing method (DREM) is used for the problem solution, and in order to improve its estimation performance, regularization is proposed and the resulting improvement is investigated analytically. The theoretical findings are illustrated in the simulations.
Regularization_and_unexcited_lre_main.pdf (336.57 Ko) Télécharger le fichier
hal-04073212 , version 1 (18-04-2023)
Paternité
  • HAL Id : hal-04073212 , version 1
Stanislav Aranovskiy, Rosane Ushirobira, Denis Efimov. On DREM regularization and unexcited linear regression estimation. 62nd IEEE Conference on Decision and Control, Dec 2023, SINGAPORE, Singapore. ⟨hal-04073212⟩
74 Consultations
96 Téléchargements
