Graph Regularized Probabilistic Matrix Factorization for Drug-Drug Interactions Prediction - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue IEEE Journal of Biomedical and Health Informatics Année : 2023
Co-administration of two or more drugs simultaneously can result in adverse drug reactions. Identifying drug-drug interactions (DDIs) is necessary, especially for drug development and for repurposing old drugs. DDI prediction can be viewed as a matrix completion task, for which matrix factorization (MF) appears as a suitable solution. This paper presents a novel Graph Regularized Probabilistic Matrix Factorization (GRPMF) method, which incorporates expert knowledge through a novel graph-based regularization strategy within an MF framework. An efficient and sounded optimization algorithm is proposed to solve the resulting non-convex problem in an alternating fashion. The performance of the proposed method is evaluated through the DrugBank dataset, and comparisons are provided against state-of-the-art techniques. The results demonstrate the superior performance of GRPMF when compared to its counterparts.
Journal_Final.pdf (380.25 Ko) Télécharger le fichier
hal-04089977 , version 1 (05-05-2023)
Stuti Jain, Emilie Chouzenoux, Kriti Kumar, Angshul Majumdar. Graph Regularized Probabilistic Matrix Factorization for Drug-Drug Interactions Prediction. IEEE Journal of Biomedical and Health Informatics, 2023, 27 (5), pp.2565-2574. ⟨10.1109/JBHI.2023.3246225⟩. ⟨hal-04089977⟩
26 Consultations
25 Téléchargements
