Revisiting Gradient Clipping: Stochastic bias and tight convergence guarantees - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Gradient clipping is a popular modification to standard (stochastic) gradient descent, at every iteration limiting the gradient norm to a certain value $c >0$. It is widely used for example for stabilizing the training of deep learning models (Goodfellow et al., 2016), or for enforcing differential privacy (Abadi et al., 2016). Despite popularity and simplicity of the clipping mechanism, its convergence guarantees often require specific values of $c$ and strong noise assumptions. In this paper, we give convergence guarantees that show precise dependence on arbitrary clipping thresholds $c$ and show that our guarantees are tight with both deterministic and stochastic gradients. In particular, we show that (i) for deterministic gradient descent, the clipping threshold only affects the higher-order terms of convergence, (ii) in the stochastic setting convergence to the true optimum cannot be guaranteed under the standard noise assumption, even under arbitrary small step-sizes. We give matching upper and lower bounds for convergence of the gradient norm when running clipped SGD, and illustrate these results with experiments.
2305.01588.pdf (784.06 Ko) Télécharger le fichier
hal-04107297 , version 1 (26-05-2023)
Paternité
Anastasia Koloskova, Hadrien Hendrikx, Sebastian U. Stich. Revisiting Gradient Clipping: Stochastic bias and tight convergence guarantees. ICML 2023 - 40th International Conference on Machine Learning, Jul 2023, Honolulu, Hawaii,, United States. pp.1-19. ⟨hal-04107297⟩
135 Consultations
106 Téléchargements
