Sensitivity Analysis of the Set of Sustainable Thresholds - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2023
In the context of constrained control-systems, the Set of Sustainable Thresholds plays in a sense the role of a dual object to the so-called Viability Kernel, because it describes all the thresholds that must be satisfied by the state of the system along a time interval, for a prescribed initial condition. This work aims at analyzing the sensitivity of the Set of Sustainable Thresholds, when it is seen as a set-valued map that depends on the initial position. In this regard, we investigate semicontinuity and Lipschitz continuity properties of this mapping, and we also study several contexts when the Set of Sustainable Thresholds is convex-valued.
Sensitivity_SST.pdf (189.38 Ko) Télécharger le fichier
hal-04112730 , version 1 (01-06-2023)
  • HAL Id : hal-04112730 , version 1
Pedro Gajardo, Thomas Guilmeau, Cristopher Hermosilla. Sensitivity Analysis of the Set of Sustainable Thresholds. 2023. ⟨hal-04112730⟩
65 Consultations
21 Téléchargements
