A continuous spatial and temporal mathematical model for assessing the distribution of dengue in Brazil with control - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of Biological Systems Année : 2023
In this paper, we developed an optimal control of a reaction–diffusion mathematical model, describing the spatial spread of dengue infection. Compartments for human and vector populations are considered in the model, including a compartment for the aquatic phase of mosquitoes. This enabled us to discuss the vertical transmission effects on the spread of the disease in a two-dimensional domain, using demographic data for different scenarios. The model was analyzed, establishing the existence and convergence of the weak solution for the model. The convergence of the numerical scheme to the weak solution was proved. For numerical approximation, we adopted the finite element scheme to solve direct and adjoint state systems. We also used the nonlinear gradient descent method to solve the optimal control problem, where the optimal management of government investment was proposed and leads to more effective dengue fever infection control. These results may help us understand the complex dynamics driven by dengue and assess the public health policies in the control of the disease.
ws-jbs-fernandolps.pdf (2.54 Mo) Télécharger le fichier
hal-04127091 , version 1 (13-06-2023)
Fernando Luiz Pio dos Santos, Mostafa Bendahmane, Elmahdi Erraji, Fahd Karami. A continuous spatial and temporal mathematical model for assessing the distribution of dengue in Brazil with control. Journal of Biological Systems, 2023, 31 (02), pp.345-373. ⟨10.1142/S0218339023300026⟩. ⟨hal-04127091⟩
29 Consultations
30 Téléchargements
