Sum-of-squares relaxations for polynomial min-max problems over simple sets - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2023
Francis Bach
We consider min-max optimization problems for polynomial functions, where a multivariate polynomial is maximized with respect to a subset of variables, and the resulting maximal value is minimized with respect to the remaining variables. When the variables belong to simple sets (e.g., a hypercube, the Euclidean hypersphere, or a ball), we derive a sum-of-squares formulation based on a primal-dual approach. In the simplest setting, we provide a convergence proof when the degree of the relaxation tends to infinity and observe empirically that it can be finitely convergent in several situations. Moreover, our formulation leads to an interesting link with feasibility certificates for polynomial inequalities based on Putinar's Positivstellensatz.
SOS_min_max.pdf (653.99 Ko) Télécharger le fichier
hal-04140288 , version 1 (25-06-2023)
Francis Bach. Sum-of-squares relaxations for polynomial min-max problems over simple sets. 2023. ⟨hal-04140288⟩
25 Consultations
127 Téléchargements
