Implicit Differentiation for Hyperparameter Tuning the Weighted Graphical Lasso - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
We provide a framework and algorithm for tuning the hyperparameters of the Graphical Lasso via a bilevel optimization problem solved with a first-order method. In particular, we derive the Jacobian of the Graphical Lasso solution with respect to its regularization hyperparameters.
main.pdf (550.25 Ko) Télécharger le fichier
hal-04151796 , version 1 (05-07-2023)
Paternité
  • HAL Id : hal-04151796 , version 1
Can Pouliquen, Paulo Gonçalves, Mathurin Massias, Titouan Vayer. Implicit Differentiation for Hyperparameter Tuning the Weighted Graphical Lasso. GRETSI 2023 - XXIXème Colloque Francophone de Traitement du Signal et des Images, Aug 2023, Grenoble (France), France. pp.1-4. ⟨hal-04151796⟩
75 Consultations
47 Téléchargements
