Convergence rate of entropy-regularized multi-marginal optimal transport costs
We investigate the convergence rate of multi-marginal optimal transport costs that are regularized with the Boltzmann-Shannon entropy, as the noise parameter ε tends to 0. We establish lower and upper bounds on the difference with the unregularized cost of the form Cε log(1/ε) + O(ε) for some explicit dimensional constants C depending on the marginals and on the ground cost, but not on the optimal transport plans themselves. Upper bounds are obtained for Lipschitz costs or locally semi-concave costs for a finer estimate, and lower bounds for $\mathscr{C}^2$ costs satisfying some signature condition on the mixed second derivatives that may include degenerate costs, thus generalizing results previously in the two marginals case and for non-degenerate costs. We obtain in particular matching bounds in some typical situations where the optimal plan is deterministic.
Nenna et Pegon - 2024 - Convergence rate of entropy-regularized multi-marg.pdf (393.88 Ko)
Télécharger le fichier
Origin : Explicit agreement for this submission
Licence : CC BY - Attribution
