A reconstruction method for the inverse gravimetric problem - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue SMAI Journal of Computational Mathematics Année : 2023
We propose a reconstruction method to solve the inverse gravimetric problem with constant mass density. The method is based on the computation of the harmonic moments of the unknown domain. Convergence results are proved and numerical experiments are provided to illustrate the method and show its efficiency.
SMAI-JCM_2023__9__197_0.pdf (6.59 Mo) Télécharger le fichier
hal-04157036 , version 1 (10-07-2023)
hal-04157036 , version 2 (09-10-2023)
Paternité
  • HAL Id : hal-04157036 , version 2
Anthony Gerber-Roth, Alexandre Munnier, Karim Ramdani. A reconstruction method for the inverse gravimetric problem. SMAI Journal of Computational Mathematics, 2023, 9, pp.197-225. ⟨hal-04157036v2⟩
64 Consultations
68 Téléchargements
