Towards Quotient Barycentric Subspaces - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Barycentric Subspaces have been defined in the context of manifolds using the notion of exponential barycenters. In this work, we extend the definition to quotient spaces which are not necessary manifolds. We define an alignment map and an horizontal logarithmic map to introduce Quotient Barycentric Subspaces (QBS). Due to the discrete group action and the quotient structure, the characterization of the subspaces and the estimation of the projection of a point onto the subspace is far from trivial. We propose two algorithms towards the estimation of the QBS and we discussed the results, underling the possible next steps for a robust estimation and their application to different data types.
Towards_Quotient_Barycentric_Subspaces.pdf (1.19 Mo) Télécharger le fichier
Licence : CC BY - Paternité
hal-04162647 , version 1 (15-07-2023)
Paternité
Anna Calissano, Elodie Maignant, Xavier Pennec. Towards Quotient Barycentric Subspaces. GSI 2023: Geometric Science of Information, Aug 2023, Saint-Malo (France), France. pp.366-374, ⟨10.1007/978-3-031-38271-0_36⟩. ⟨hal-04162647⟩
61 Consultations
78 Téléchargements
