OpenCCO: An Implementation of Constrained Constructive Optimization for Generating 2D and 3D Vascular Trees - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Image Processing On Line Année : 2023
In this article, we focus on the algorithm called CCO (Constrained Constructive Optimization), initially proposed by Schreiner and Buxbaum. This algorithm can be considered as one of the gold standards for vascular tree structure generation. Modeling and/or simulating the morphology of vascular networks is a challenging but crucial task that can have a strong impact on different applications such as fluid simulation or learning processes related to image segmentation. Various implementations of CCO were proposed over the last years. However, to the best of our knowledge, there does not exist any open-source version that faithfully follows the native CCO algorithm. Our purpose is to propose such an implementation both in 2D and 3D.
Kerautret_IPOL_2023.pdf (5.49 Mo) Télécharger le fichier
hal-04201337 , version 1 (15-10-2023)
Bertrand Kerautret, Phuc Ngo, Nicolas Passat, Hugues Talbot, Clara Jaquet. OpenCCO: An Implementation of Constrained Constructive Optimization for Generating 2D and 3D Vascular Trees. Image Processing On Line, 2023, 13, pp.258-279. ⟨10.5201/ipol.2023.477⟩. ⟨hal-04201337⟩
242 Consultations
55 Téléchargements
