GPU Code Generation of Cardiac Electrophysiology Simulation with MLIR - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
We show the benefits of the novel MLIR compiler technology to the generation of code from a DSL, namely EasyML used in openCARP, a widely used simulator in the cardiac electrophysiology community. Building on an existing work that deeply modified open-CARP's native DSL code generator to enable efficient vectorized CPU code, we extend the code generation for GPUs (Nvidia CUDA and AMD ROCm). Generating optimized code for different accelerators requires specific optimizations and we review how MLIR has been used to enable multi-target code generation from an integrated generator. Experiments conducted on the 48 ionic models provided by openCARP show that the GPU code executes 3.17× faster and delivers more than 7× FLOPS per watt than the vectorized CPU code, on an Nvidia A100 GPU versus a 36-cores AVX-512 Intel CPU.
2023_EuroPar_ODE_to_MLIR_to_GPU_Optimized_code (1).pdf (611.75 Ko) Télécharger le fichier
hal-04206195 , version 1 (13-09-2023)
Paternité
Tiago Trevisan Jost, Arun Thangamani, Raphaël Colin, Vincent Loechner, Stéphane Genaud, et al.. GPU Code Generation of Cardiac Electrophysiology Simulation with MLIR. Euro-Par 2023: Parallel Processing, Aug 2023, Limassol, Cyprus. pp.549-563, ⟨10.1007/978-3-031-39698-4_37⟩. ⟨hal-04206195⟩
31 Consultations
114 Téléchargements
