On the analysis of a mechanically consistent model of fluid-structure-contact interaction - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Mathematics in Engineering Année : 2024
This paper is devoted to the mathematical analysis of the contact capabilities of the fluidstructure interaction (FSI) model with seepage reported in [Comput. Methods Appl. Mech., 392:114637, 2022]. In the case of a rigid disk moving over a fixed horizontal plane, we show that this model encompasses contact and hence removes the non collision paradox of traditional FSI models which rely on Dirichlet or Dirichlet/Navier boundary conditions. Numerical evidence on the theoretical results is also provided.
paper_m3as.pdf (2.2 Mo) Télécharger le fichier
hal-04229012 , version 1 (05-10-2023)
Paternité
  • HAL Id : hal-04229012 , version 1
Marguerite Champion, Miguel Angel Fernández, Céline Grandmont, Fabien Vergnet, Marina Vidrascu. On the analysis of a mechanically consistent model of fluid-structure-contact interaction. Mathematics in Engineering, In press. ⟨hal-04229012⟩
49 Consultations
88 Téléchargements
