Tracing task-based runtime systems: Feedbacks from the StarPU case - Inria - Institut national de recherche en sciences et technologies du numérique Access content directly
Journal Articles Concurrency and Computation: Practice and Experience Year : 2023
Given the complexity of current supercomputers and applications, being able to trace application executions to understand their behaviour is not a luxury. As constraints, tracing systems have to be as little intrusive as possible in the application code and performances, and be precise enough in the collected data. In this article, we present how works the tracing system used by the task-based runtime system StarPU. We study the different sources of performance overhead coming from the tracing system and how to reduce these overheads. Then, we evaluate the accuracy of distributed traces with different clock synchronization techniques. Finally, we summarize our experiments and conclusions with the lessons we learned to efficiently trace applications, and the list of characteristics each tracing system should feature to be competitive. The reported experiments and implementation details comprise a feedback of integrating into a task-based runtime system state-of-the-art techniques to efficiently and precisely trace application executions. We highlight the points every application developer or end-user should be aware of to seamlessly integrate a tracing system or just trace application executions.
article.pdf (1.37 Mo) Télécharger le fichier
Dates and versions
hal-04236246 , version 1 (10-10-2023)
Attribution
Identifiers
Cite
Alexandre Denis, Emmanuel Jeannot, Philippe Swartvagher, Samuel Thibault. Tracing task-based runtime systems: Feedbacks from the StarPU case. Concurrency and Computation: Practice and Experience, 2023, pp.24. ⟨10.1002/cpe.7920⟩. ⟨hal-04236246⟩
105 View
107 Download
Share
