Optimization Methods for Signal Processing - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Chapitre D'ouvrage Année : 2023
In a wide range of problems arising in source separation, large scale optimization problems need to be solved. The objective of this chapter is to introduce the theoretical background which makes it possible to develop efficient algorithms to successfully address these problems. This chapter will be mainly focused on nonlinear optimization tools for dealing with convex and nonconvex problems. Proximal tools, parallel splitting techniques, Majorization-Minimization strategies and alternating minimization approaches will be presented. Illustrations of these methods on various problems will be provided.
main.pdf (2.05 Mo) Télécharger le fichier
hal-04250055 , version 1 (12-12-2023)
Paternité
  • HAL Id : hal-04250055 , version 1
Emilie Chouzenoux, Jean-Christophe Pesquet. Optimization Methods for Signal Processing. C.Jutten, L.T. Duarte, S. Moussaoui. Source Separation in Physical-Chemical Sensing, Chapter 2, IEEE Press; JOHN WILEY & SONS, 2023, 9781119137276. ⟨hal-04250055⟩
38 Consultations
63 Téléchargements
