TLR-9 agonist and CD40-targeting vaccination induces HIV-1 envelope-specific B cells with a diversified immunoglobulin repertoire in humanized mice - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue PLoS Pathogens Année : 2020
Hugo Mouquet
The development of HIV-1 vaccines is challenged by the lack of relevant models to accurately induce human Band T-cell responses in lymphoid organs. In humanized mice reconstituted with human hematopoietic stem cells (hu-mice), human B cell-development and function are impaired and cells fail to efficiently transition from IgM B cells to IgG B cells. Here, we found that CD40-targeted vaccination combined with CpG-B adjuvant overcomes the usual defect of human B-cell switch and maturation in hu-mice. We further dissected huB cell responses directed against the HIV-1 Env protein elicited by targeting Env gp140 clade C to the CD40 receptor of antigen-presenting cells. The anti-CD40.Env gp140 vaccine was injected with CpG-B in a homologous prime/boost regimen or as a boost of a NYVAC-KC pox vector encoding Env gp140 clade C. Both regimens elicited Env-specific IgGswitched memory huB cells at a greater magnitude in hu-mice primed with NYVAC-KC. Single-cell RNA-seq analysis showed gp140-specific huB cells to express polyclonal IgG1 and IgG3 isotypes and a broad Ig VH/VL repertoire, with predominant VH3 family gene usage. These cells exhibited a higher rate of somatic hypermutation than the non-specific IgG + huB cell counterpart. Both vaccine regimens induced splenic GC-like structures containing huB and hu-Tfh-like cells expressing PD-1 and BCL-6. We confirmed in this model that circulating ICOS + memory hu-Tfh cells correlated with the magnitude of gp140-specific B-cell responses. Finally, the NYVAC-KC heterologous prime led to a more diverse clonal
document.pdf (2.48 Mo) Télécharger le fichier
Licence : CC BY - Paternité
hal-04296375 , version 1 (20-11-2023)
Paternité
Véronique Godot, Colas Tcherakian, Laurine Gil, Iñaki Cervera-Marzal, Guangming Li, et al.. TLR-9 agonist and CD40-targeting vaccination induces HIV-1 envelope-specific B cells with a diversified immunoglobulin repertoire in humanized mice. PLoS Pathogens, 2020, 16, ⟨10.1371/journal.ppat.1009025⟩. ⟨hal-04296375⟩
46 Consultations
9 Téléchargements
