State-dependent Preconditioning for Data Assimilation - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Poster Année : 2023
Variational Data Assimilation requires the optimization of a high-dimensional function. This is usually done by linearizing the problem, and then inverting the Gauss-Newton matrix. ¿ Can we build a state-dependent preconditioner which would help for the inversion of the linear system ?
TRAPPLER_Victor_State_Dependent_Preconditioning_for_Variational_Data_Assimilation.pdf (744.28 Ko) Télécharger le fichier
hal-04309242 , version 1 (27-11-2023)
Paternité
  • HAL Id : hal-04309242 , version 1
Victor Trappler, Arthur Vidard. State-dependent Preconditioning for Data Assimilation: Application to a Shallow Water Assimilation system. ISDA 2023 - 9th International Symposium on Data Assimilation, Oct 2023, Bologne, Italy. , pp.1-1, 2023. ⟨hal-04309242⟩
22 Consultations
13 Téléchargements
