Secure method for data exchange between a terminal and a server - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Brevet Année : 2023
A secure method for data exchange between a terminal and a server is described. The server can use a cryptographic module configured to encrypt or decrypt a message based on input parameters comprising the message, a response to a challenge and a symmetric key. The terminal can use a white-box cryptography module constituting a white-box implementation of the cryptographic module of the server for this symmetric key.
Fichier non déposé
hal-04313153 , version 1 (29-11-2023)
  • HAL Id : hal-04313153 , version 1
Marine Minier, Sandra Rasoamiaramanana, Gilles Macario-Rat. Secure method for data exchange between a terminal and a server. France, Patent n° : US Patent App. 17/777,906. 2023. ⟨hal-04313153⟩
18 Consultations
0 Téléchargements
