A mixed-dimensional formulation for the simulation of slender structures immersed in an incompressible flow - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2023
We consider the simulation of slender structures immersed in a three-dimensional (3D) flow. By exploiting the special geometric configuration of the slender structures, this particular problem can be modeled by mixed-dimensional coupled equations (3D for the fluid and 1D for the solid). Several challenges must be faced when dealing with this type of problems. From a mathematical point of view, these include defining wellposed trace operators of codimension two. On the computational standpoint, the nonstandard mathematical formulation makes it difficult to ensure the accuracy of the solutions obtained with the mixed-dimensional discrete formulation as compared to a fully resolved one. We establish the continuous formulation using the Navier-Stokes equations for the fluid and a Timoshenko beam model for the structure. We complement these models with a mixed-dimensional version of the fluid-structure interface conditions, based on the projection of kinematic coupling conditions on a finite-dimensional Fourier space. Furthermore, we develop a discrete formulation within the framework of the finite element method, establish the energy stability of the scheme, provide extensive numerical evidence of the accuracy of the discrete formulation, notably with respect to a fully resolved (ALE based) model and a standard reduced modeling approach.
FSI__Navier_Stokes___3D1D-18.pdf (33.29 Mo) Télécharger le fichier
hal-04318526 , version 1 (01-12-2023)
Paternité
  • HAL Id : hal-04318526 , version 1
Fabien Lespagnol, Céline Grandmont, Paolo Zunino, Miguel Angel Fernández. A mixed-dimensional formulation for the simulation of slender structures immersed in an incompressible flow. 2023. ⟨hal-04318526⟩
105 Consultations
90 Téléchargements
