Review of reliability assessment methods of drone swarm (fleet) and a new importance evaluation based method of drone swarm structure analysis - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Mathematics Année : 2023
Drones, or UAVs, are developed very intensively. There are many effective applications of drones for problems of monitoring, searching, detection, communication, delivery, and transportation of cargo in various sectors of the economy. The reliability of drones in the resolution of these problems should play a principal role. Therefore, studies encompassing reliability analysis of drones and swarms (fleets) of drones are important. As shown in this paper, the analysis of drone reliability and its components is considered in studies often. Reliability analysis of drone swarms is investigated less often, despite the fact that many applications cannot be performed by a single drone and require the involvement of several drones. In this paper, a systematic review of the reliability analysis of drone swarms is proposed. Based on this review, a new method for the analysis and quantification of the topological aspects of drone swarms is considered. In particular, this method allows for the computing of swarm availability and importance measures. Importance measures in reliability analysis are used for system maintenance and to indicate the components (drones) whose fault has the most impact on the system failure. Structural and Birnbaum importance measures are introduced for drone swarms’ components. These indices are defined for the following topologies: a homogenous irredundant drone fleet, a homogenous hot stable redundant drone fleet, a heterogeneous irredundant drone fleet, and a heterogeneous hot stable redundant drone fleet.
hal-04358308 , version 1 (21-12-2023)
Elena Zaitseva, Vitaly Levashenko, Ravil Mukhamediev, Nicolae Brinzei, Andriy Kovalenko, et al.. Review of reliability assessment methods of drone swarm (fleet) and a new importance evaluation based method of drone swarm structure analysis. Mathematics , 2023, 11 (11), pp.2551. ⟨10.3390/math11112551⟩. ⟨hal-04358308⟩
27 Consultations
0 Téléchargements
