Online Primal-Dual Algorithm with Predictions for Non-Linear Covering Problems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2023
Enikő Kevi
Nguyễn Kim Thắng
Designing online algorithms with predictions is a recent technique for various practically relevant online problems (scheduling, caching (paging), clustering, ski rental, etc.). [8] provided a unified approach through a primal-dual framework for linear covering problems. Their framework extends the online primal-dual method by incorporating predictions, and its performance goes beyond the worst-case analysis. Following this research line, our paper presents competitive algorithms with predictions for non-linear covering problems, generalizing the previous technique. We illustrate the applicability of our algorithms through experiments on energy minimization, congestion management, and submodular minimization problems.
main.pdf (662.45 Ko) Télécharger le fichier
Licence : CC BY NC - Paternité - Pas d'utilisation commerciale
hal-04361128 , version 1 (22-12-2023)
  • HAL Id : hal-04361128 , version 1
Enikő Kevi, Nguyễn Kim Thắng. Online Primal-Dual Algorithm with Predictions for Non-Linear Covering Problems. 2023. ⟨hal-04361128⟩
67 Consultations
38 Téléchargements
