A first-order reduced model for a highly oscillating differential equation with application in Penning traps - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail (Preprint/Prepublication) Année : 2023
We derive a reduced first-order model from a two-scale asymptotic expansion in a small parameter, in order to approximate the solution of a stiff differential equation. The problem of interest is a multi-scale Newton-Lorentz equation modeling the dynamics of a charged particle under the influence of a linear electric field and of a perturbed strong magnetic field. First, we show that in short times, the first-order model provides a much better approximation than the zero-order one, since it contains terms evolving at slow time scales. Then, thanks to the source-free property of the equations, we propose a volume-preserving method using a particular splitting technique to solve numerically the first-order model. Finally, it turns out that the first-order model does not systematically provide a satisfactory approximation in long times. To overcome this issue, we implement a recent strategy based on the Parareal algorithm, in which the first-order approximation is used for the coarse solver. This approach allows to perform efficient and accurate long-time simulations for any small parameter. Numerical results for two realistic Penning traps are provided to support these statements.
hal.pdf (575.41 Ko) Télécharger le fichier
hal-04361370 , version 1 (22-12-2023)
Paternité
  • HAL Id : hal-04361370 , version 1
Sever Adrian Hirstoaga. A first-order reduced model for a highly oscillating differential equation with application in Penning traps. 2023. ⟨hal-04361370⟩
64 Consultations
26 Téléchargements
