Solving LP-MPC problems using ramp functions* - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
A new implementation of the Simplex method for solving linear programming problems is developed, and its application for solving MPC problems with linear objective functions is described. A detailed comparison with existing implementations of the Simplex method is beyond the scope of this paper. However, initial numerical results indicate that gains in calculation times may be achieved for problems of small to moderate size.
LP_MPC.pdf (303.13 Ko) Télécharger le fichier
hal-04363933 , version 1 (26-12-2023)
Morten Hovd, Giorgio Valmorbida. Solving LP-MPC problems using ramp functions*. CCTA 2023 - 7th IEEE Conference on Control Technology and Applications, Aug 2023, Bridgetown, Barbados. pp.445-450, ⟨10.1109/CCTA54093.2023.10252720⟩. ⟨hal-04363933⟩
30 Consultations
20 Téléchargements
