Output feedback control of discrete-time Lur'e systems through FIR Zames-Falb multipliers
This paper is concerned with output feedback control of discrete-time Lur'e systems with slope bounded nonlinearities that can be non-odd. Using FIR (Finite Impulse Response) Zames-Falb multipliers of any given order, stability conditions based on positive realness are proposed in terms of linear matrix inequalities and linear constraints that assure the ℓ 1 norm bound for the multiplier. Importantly, the proposed approach does not require line searches. Applying a relaxation on the stability and exploiting the fact that the matrices of the system appear affinely in the conditions, an iterative method is constructed to search for the FIR Zames-Falb multiplier certifying stability. An extension to cope with the design of a control law is also presented, dealing with state or output feedback gains that may include a term proportional to the output of the nonlinear block. Numerical examples illustrate the advantages of the proposed approach, that can be numerically more efficient than other techniques from the literature.
Mots clés
Discrete-time Lur'e systems FIR Zames-Falb multipliers Absolute stability Output-feedback control Linear matrix inequalities Discrete-time Lur'e systems FIR Zames-Falb multipliers Absolute stability Output-feedback control Linear matrix inequalities Discrete-time Lur'e systems FIR Zames-Falb multipliers Absolute stability Output-feedback control Linear matrix inequalities Discrete-time Lur'e systems FIR Zames-Falb multipliers Absolute stability Output-feedback control Linear matrix inequalities Discrete-time Lur'e systems FIR Zames-Falb multipliers Absolute stability Output-feedback control Linear matrix inequalities Discrete-time Lur'e systems FIR Zames-Falb multipliers Absolute stability Output-feedback control Linear matrix inequalities Discrete-time Lur'e systems FIR Zames-Falb multipliers Absolute stability Output-feedback control Linear matrix inequalities Discrete-time Lur'e systems FIR Zames-Falb multipliers Absolute stability Output-feedback control Linear matrix inequalities
Absolute stability
Automatique / Robotique
