Output feedback control of discrete-time Lur'e systems through FIR Zames-Falb multipliers - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
This paper is concerned with output feedback control of discrete-time Lur'e systems with slope bounded nonlinearities that can be non-odd. Using FIR (Finite Impulse Response) Zames-Falb multipliers of any given order, stability conditions based on positive realness are proposed in terms of linear matrix inequalities and linear constraints that assure the ℓ 1 norm bound for the multiplier. Importantly, the proposed approach does not require line searches. Applying a relaxation on the stability and exploiting the fact that the matrices of the system appear affinely in the conditions, an iterative method is constructed to search for the FIR Zames-Falb multiplier certifying stability. An extension to cope with the design of a control law is also presented, dealing with state or output feedback gains that may include a term proportional to the output of the nonlinear block. Numerical examples illustrate the advantages of the proposed approach, that can be numerically more efficient than other techniques from the literature.
1-s2.0-S2405896323006031-main.pdf (438.66 Ko) Télécharger le fichier
hal-04363973 , version 1 (26-12-2023)
Paternité - Pas d'utilisation commerciale - Pas de modification
Ariádne L.J. Bertolin, Ricardo C.L.F. Oliveira, Giorgio Valmorbida, Pedro L.D. Peres. Output feedback control of discrete-time Lur'e systems through FIR Zames-Falb multipliers. 22nd World Congress of the International Federation of Automatic Control (IFAC 2023), Ifac, Jul 2023, Yokohama, France. pp.9528-9533, ⟨10.1016/j.ifacol.2023.10.252⟩. ⟨hal-04363973⟩
22 Consultations
16 Téléchargements
