Convergence of Proximal Point and Extragradient-Based Methods Beyond Monotonicity: the Case of Negative Comonotonicity - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Algorithms for min-max optimization and variational inequalities are often studied under monotonicity assumptions. Motivated by non-monotone machine learning applications, we follow the line of works [Diakonikolas et al., 2021, Lee and Kim, 2021, Pethick et al., 2022, Böhm, 2022] aiming at going beyond monotonicity by considering the weaker negative comonotonicity assumption. In particular, we provide tight complexity analyses for the Proximal Point, Extragradient, and Optimistic Gradient methods in this setup, closing some questions on their working guarantees beyond monotonicity.
hal-04384208 , version 1 (10-01-2024)
Eduard Gorbunov, Adrien Taylor, Samuel Horváth, Gauthier Gidel. Convergence of Proximal Point and Extragradient-Based Methods Beyond Monotonicity: the Case of Negative Comonotonicity. ICML 2023 - 40th International Conference on Machine Learning, Jul 2023, Honolulu, Hawai, United States. ⟨10.48550/arXiv.2210.13831⟩. ⟨hal-04384208⟩
19 Consultations
0 Téléchargements
