Automated tight Lyapunov analysis for first-order methods - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2023
We present a methodology for establishing the existence of quadratic Lyapunov inequalities for a wide range of first-order methods used to solve convex optimization problems. In particular, we consider i) classes of optimization problems of finite-sum form with (possibly strongly) convex and possibly smooth functional components, ii) first-order methods that can be written as a linear system on state-space form in feedback interconnection with the subdifferentials of the functional components of the objective function, and iii) quadratic Lyapunov inequalities that can be used to draw convergence conclusions. We provide a necessary and sufficient condition for the existence of a quadratic Lyapunov inequality that amounts to solving a small-sized semidefinite program. We showcase our methodology on several first-order methods that fit the framework. Most notably, our methodology allows us to significantly extend the region of parameter choices that allow for duality gap convergence in the Chambolle-Pock method when the linear operator is the identity mapping.
hal-04384212 , version 1 (10-01-2024)
Manu Upadhyaya, Sebastian Banert, Adrien Taylor, Pontus Giselsson. Automated tight Lyapunov analysis for first-order methods. 2024. ⟨hal-04384212⟩
21 Consultations
0 Téléchargements
