Nonlinear conjugate gradient methods: worst-case convergence rates via computer-assisted analyses - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2023
We propose a computer-assisted approach to the analysis of the worst-case convergence of nonlinear conjugate gradient methods (NCGMs). Those methods are known for their generally good empirical performances for large-scale optimization, while having relatively incomplete analyses. Using our computer-assisted approach, we establish novel complexity bounds for the Polak-Ribière-Polyak (PRP) and the Fletcher-Reeves (FR) NCGMs for smooth strongly convex minimization. In particular, we construct mathematical proofs that establish the first non-asymptotic convergence bound for FR (which is historically the first developed NCGM), and a much improved non-asymptotic convergence bound for PRP. Additionally, we provide simple adversarial examples on which these methods do not perform better than gradient descent with exact line search, leaving very little room for improvements on the same class of problems.
hal-04384219 , version 1 (10-01-2024)
Shuvomoy Das Gupta, Robert Freund, Xu Andy Sun, Adrien Taylor. Nonlinear conjugate gradient methods: worst-case convergence rates via computer-assisted analyses. 2024. ⟨hal-04384219⟩
18 Consultations
0 Téléchargements
