Second-order Averaging of Low-Thrust Transfers in Fixed Time * - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of Guidance, Control, and Dynamics Année : 2024
An algorithm for the second-order approximation of fixed-time, low-thrust orbital transfersand generation of Bacon plots is proposed. After averaging the extremal flow of the optimal-control Hamiltonian, a one-parameter family of solutions of a reduced-order, two-point boundary value problems is computed by means of a differential-continuation scheme. Sensitivities of the shooting function are then used in conjunction with an ad hoc near-identity transformation between averaged and osculating variables to achieve an accurate solution for all longitudes of the departure and arrival orbits. Hence, a single simplified shooting problem has to be solved to approximate the solution for any combination of departure and arrival dates, and to draw a Bacon plot for an arbitrary launch window. Both the averaged flow and the near-identity transformation are efficiently evaluated via the fast-Fourier transform algorithm, yielding a fully-numerical procedure.
LowThrustLambert_v3.pdf (2.26 Mo) Télécharger le fichier
hal-04387944 , version 1 (11-01-2024)
Paternité
  • HAL Id : hal-04387944 , version 1
Lamberto Dell'Elce, Alesia Herasimenka, Aaron J Rosengren, Nicola Baresi. Second-order Averaging of Low-Thrust Transfers in Fixed Time *. Journal of Guidance, Control, and Dynamics, inPress. ⟨hal-04387944⟩
39 Consultations
34 Téléchargements
