Conditional Generative Models for Simulation of EMG During Naturalistic Movements - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2024
Numerical models of electromyographic (EMG) signals have provided a huge contribution to our fundamental understanding of human neurophysiology and remain a central pillar of motor neuroscience and the development of human-machine interfaces. However, whilst modern biophysical simulations based on finite element methods are highly accurate, they are extremely computationally expensive and thus are generally limited to modelling static systems such as isometrically contracting limbs. As a solution to this problem, we propose a transfer learning approach, in which a conditional generative model is trained to mimic the output of an advanced numerical model. To this end, we present BioMime, a conditional generative neural network trained adversarially to generate motor unit activation potential waveforms under a wide variety of volume conductor parameters. We demonstrate the ability of such a model to predictively interpolate between a much smaller number of numerical model's outputs with a high accuracy. Consequently, the computational load is dramatically reduced, which allows the rapid simulation of EMG signals during truly dynamic and naturalistic movements.
2211.01856.pdf (4.82 Mo) Télécharger le fichier
hal-04390148 , version 1 (12-01-2024)
Paternité
Shihan Ma, Alexander Kenneth Clarke, Kostiantyn Maksymenko, Samuel Deslauriers-Gauthier, Xinjun Sheng, et al.. Conditional Generative Models for Simulation of EMG During Naturalistic Movements. 2024. ⟨hal-04390148⟩
82 Consultations
346 Téléchargements
