A note on fixed-and discrete-time estimation via the DREM method - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue IEEE Transactions on Automatic Control Année : 2024
A simple fixed-time converging estimation algorithm is presented for a linear regression using the dynamic regressor extension and mixing (DREM) method within a discrete-time setting, with a persistently excited regressor and bounded measurement noises. The solution is based on Kreisselmeier's filters, and it is computationally simpler than the existing analogs.
KremAndScalarLRE_TAC.pdf (329.78 Ko) Télécharger le fichier
hal-04393160 , version 1 (14-01-2024)
Paternité
Marina Korotina, Stanislav Aranovskiy, Rosane Ushirobira, Denis Efimov, Jian Wang. A note on fixed-and discrete-time estimation via the DREM method. IEEE Transactions on Automatic Control, 2024, pp.1-6. ⟨10.1109/TAC.2024.3355803⟩. ⟨hal-04393160⟩
20 Consultations
28 Téléchargements
