Space and time continuous physics simulation from partial observations - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2024
Modern techniques for physical simulations rely on numerical schemes and meshrefinement methods to address trade-offs between precision and complexity, but these handcrafted solutions are tedious and require high computational power. Data-driven methods based on large-scale machine learning promise high adaptivity by integrating long-range dependencies more directly and efficiently. In this work, we focus on fluid dynamics and address the shortcomings of a large part of the literature, which are based on fixed support for computations and predictions in the form of regular or irregular grids. We propose a novel setup to perform predictions in a continuous spatial and temporal domain while being trained on sparse observations. We formulate the task as a double observation problem and propose a solution with two interlinked dynamical systems defined on, respectively, the sparse positions and the continuous domain, which allows to forecast and interpolate a solution from the initial condition. Our practical implementation involves recurrent GNNs and a spatio-temporal attention observer capable of interpolating the solution at arbitrary locations. Our model not only generalizes to new initial conditions (as standard auto-regressive models do) but also performs evaluation at arbitrary space and time locations. We evaluate on three standard datasets in fluid dynamics and compare to strong baselines, which are outperformed both in classical settings and in the extended new task requiring continuous predictions.
ICLR24_Steeven_NerfPDE.pdf (22.66 Mo) Télécharger le fichier
hal-04464153 , version 1 (20-02-2024)
  • HAL Id : hal-04464153 , version 1
Steeven Janny, Madiha Nadri, Julie Digne, Christian Wolf. Space and time continuous physics simulation from partial observations. International Conference on Learning Representation, May 2024, Vienna, Austria. ⟨hal-04464153⟩
48 Consultations
4 Téléchargements
