Surface boundary layers through a scalar equation with an eddy viscosity vanishing at the ground - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue ESAIM: Mathematical Modelling and Numerical Analysis Année : 2024
We introduce a scalar elliptic equation defined on a boundary layer given by Π 2 × [0, z top ], where Π 2 is a two dimensional torus, with an eddy vertical eddy viscosity of order z α , α ∈ [0, 1], an homogeneous boundary condition at z = 0, and a Robin condition at z = z top. We show the existence of weak solutions to this boundary problem, distinguishing the cases 0 ≤ α < 1 and α = 1. Then we carry out several numerical simulations, showing the ability of our model to accuratly reproduce profiles close to those predicted by the Monin-Oboukhov theory, by calculating stabilizing functions.
Lin_Bound_Layer_V5.pdf (586.32 Ko) Télécharger le fichier
hal-04533458 , version 1 (29-11-2022)
hal-04533458 , version 2 (16-01-2023)
hal-04533458 , version 3 (04-04-2024)
  • HAL Id : hal-04533458 , version 2
Luigi Carlo Berselli, François Legeais, Roger Lewandowski. Surface boundary layers through a scalar equation with an eddy viscosity vanishing at the ground. ESAIM: Mathematical Modelling and Numerical Analysis, 2024, 58 (2), pp.489-513. ⟨hal-04533458v2⟩
152 Consultations
61 Téléchargements
