Surface boundary layers through a scalar equation with an eddy viscosity vanishing at the ground - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue ESAIM: Mathematical Modelling and Numerical Analysis Année : 2024
We introduce a scalar elliptic equation defined on a boundary layer given by Π2 × [0, ztop], where Π2 is a two dimensional torus, with an eddy vertical viscosity of order zα, α ∈ [0, 1], an homogeneous boundary condition at z = 0, and a Robin condition at z = ztop. We show the existence of weak solutions to this boundary problem, distinguishing the cases 0 ≤ α < 1 and α = 1. Then we carry out several numerical simulations, showing the ability of our model to accurately reproduce profiles close to those predicted by the Monin–Obukhov theory, by calculating stabilizing functions.
m2an230011.pdf (1.3 Mo) Télécharger le fichier
Origine : Publication financée par une institution
hal-04533458 , version 1 (29-11-2022)
hal-04533458 , version 2 (16-01-2023)
hal-04533458 , version 3 (04-04-2024)
Paternité
Luigi C. Berselli, François Legeais, Roger Lewandowski. Surface boundary layers through a scalar equation with an eddy viscosity vanishing at the ground. ESAIM: Mathematical Modelling and Numerical Analysis, 2024, 58 (2), pp.489-513. ⟨10.1051/m2an/2024009⟩. ⟨hal-04533458v3⟩
152 Consultations
61 Téléchargements
