Feedback Stabilization of Discrete-Time Switched Systems Under Büchi-Constrained Signals - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue IEEE Control Systems Letters Année : 2024
This manuscript studies the feedback stabilization problem for a class of discrete-time switched systems. The goal is the design, via semidefinite optimization techniques, of feedback control rules depending only on the current state variable and on the past values of the underlying switching sequence. The resulting control policy achieves uniform exponential stabilization over a pre-constructed class of switching signals. The overall construction generalizes known approaches for stabilization over arbitrary switching sequences}, but it is able to stabilize systems for which none of the defining subsystems is stabilizable. This extension is obtained employing graph-theoretic tools, introducing the Büchi automata formalism in order to specify the considered classes of admissible sequences, seen here in the general setting of omega-regular languages. The proposed construction is finally illustrated with the help of a numerical example.
HAL.pdf (341.72 Ko) Télécharger le fichier
hal-04568067 , version 1 (03-05-2024)
M. Della Rossa, Thiago Alves Lima, Antoine Girard. Feedback Stabilization of Discrete-Time Switched Systems Under Büchi-Constrained Signals. IEEE Control Systems Letters, 2024, 8, pp.418-423. ⟨10.1109/LCSYS.2024.3391659⟩. ⟨hal-04568067⟩
0 Consultations
0 Téléchargements
