Car-Like Robots and Moving Obstacles - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 1994
This paper addresses motion planning for a car-like robot moving in a changing planar workspace, i.e. with moving obstacles. First, this motion planning problem is formulated in the `state-time space' framework. The state-time space of a robot is its state space plus the time dimension. In this framework part of the constraints at hand are translated into static forbidden regions of state-time space, and a trajectory maps to a state-time curve which must respect the remaining constraints. Then an approximate solution to the problem is presented.
Fichier non déposé
inria-00000023 , version 1 (12-05-2005)
Thierry Fraichard, Alexis Scheuer. Car-Like Robots and Moving Obstacles. IEEE Int. Conf. on Robotics and Automation, May 1994, San Diego, California (US), United States. pp.64-69, ⟨10.1109/ROBOT.1994.351009⟩. ⟨inria-00000023⟩
150 Consultations
0 Téléchargements
