A method of Lagrange--Galerkin of second order in time - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Autre Publication Comptes rendus de l'Académie des sciences. Série I, Mathématique Année : 2005
The Lagrange--Galerkin method is the coupling of a finite element method for space discretisation with the method of characteristics for the discretisation of the material derivative in some parabolic problems. We propose a new scheme of second-order accuracy in time, which in contrast with previous methods does not require a correction term. Numerical examples, including Burgers equation, illustrate the convergence rate and low computational cost of the method.
HAL.pdf (135.04 Ko) Télécharger le fichier
inria-00000402 , version 1 (05-10-2005)
  • HAL Id : inria-00000402 , version 1
Jocelyn Etienne. A method of Lagrange--Galerkin of second order in time. 2005. ⟨inria-00000402⟩
Collections
TDS-MACS
69 Consultations
84 Téléchargements
