Perturbed Path Following Interior Point Algorithms - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 1995
J. Frederic Bonnans
  • Fonction : Auteur
  • PersonId : 833418
  • IdHAL : bonnans
Cécilia Pola
  • Fonction : Auteur
The path following algorithms of predictor corrector type have proved to be very effective for solving linear optimization problems. However, the assumption that the Newton direction (corresponding to a centering or affine step) is computed exactly is unrealistic. Indeed, for large scale problems, one may need to use iterative algorithms for computing the Newton step. In this paper, we study algorithms in which the computed direction is the solution of the usual linear system with an error in the right-hand-side. We give precise and explicit estimates of the error under which the computational complexity is the same as for the standard case. We also give explicit estimates that guarantee an asymptotic linear convergence at an arbitrary rate. Because our results are in the framework of monotone linear complementarity problems, our results apply to convex quadratic optimization as well.
RR-2745.pdf (284.19 Ko) Télécharger le fichier
inria-00073947 , version 1 (24-05-2006)
  • HAL Id : inria-00073947 , version 1
J. Frederic Bonnans, Cécilia Pola, Raja Rébaï. Perturbed Path Following Interior Point Algorithms. [Research Report] RR-2745, INRIA. 1995. ⟨inria-00073947⟩
92 Consultations
111 Téléchargements
